6 String Sapele and Cedar Photo Set http://www-.luthiersforum.com/forum/viewtopic.php?f=10128&t=49212 |
Author: | Allen McFarlen [ Wed Apr 05, 2017 3:40 pm ] |
Post subject: | 6 String Sapele and Cedar Photo Set |
I've had this set of Sapele on the shelf for about 8 years waiting for a special project to warrant using it. Don't mind saying I was pretty nervouse bending those sides. Body - Sapele Soundboard - Western Red Cedar Peg Head Veneers - Sapele Fret Board - Macasar Ebony with 12" - 16" compound radius Rosette - Spalted Maple Bindings - Indian Rosewood Tuners - Waverly with Snake Wood buttons Finish - High gloss lacquer Attachment: 6 String Sapele Tenor-4.jpg Attachment: 6 String Sapele Tenor-7.jpg Attachment: 6 String Sapele Tenor-2.jpg Attachment: 6 String Sapele Tenor-10.jpg Attachment: 6 String Sapele Tenor-12.jpg Attachment: 6 String Sapele Tenor-14.jpg Attachment: 6 String Sapele Tenor-15.jpg Attachment: 6 String Sapele Tenor-13.jpg
Author: | Chris Pile [ Wed Apr 05, 2017 6:58 pm ] |
Post subject: | Re: 6 String Sapele and Cedar Photo Set |
ERMAGAWD! Like chewy candy.... |
Author: | Pmaj7 [ Wed Apr 05, 2017 7:10 pm ] |
Nize! |
Author: | bcombs510 [ Wed Apr 05, 2017 7:30 pm ] |
Stunning! Sent from my iPhone using Tapatalk |
Author: | SteveSmith [ Wed Apr 05, 2017 7:53 pm ] |
Gorgeous! Sent from my SM-G930V using Tapatalk |
Author: | Bryan Bear [ Fri Apr 14, 2017 1:46 pm ] |
Author: | johnparchem [ Fri Apr 14, 2017 1:59 pm ] |
very nice! |
Author: | Quine [ Tue Apr 18, 2017 11:43 am ] |
Wow...I've never seen sapele like that before. Looks gorgeous with that satin finish |
Author: | Ruby50 [ Tue Apr 18, 2017 7:58 pm ] |
Beautifully conceived and executed Ed |
Author: | truckjohn [ Tue Apr 18, 2017 9:55 pm ] |
Beautiful! Very clean. |
Author: | J De Rocher [ Tue Apr 18, 2017 10:16 pm ] |
There are so many details about this instrument to like and they all work together. The oval sound hole really fits the elongated body shape, IMO. Sorry if you have covered this in another thread before, but could you describe how the two-piece pinless bridge works? Is the lighter colored piece behind the main bridge glued to the top? Are the strings threaded through the back end of the light colored piece? |
Author: | Chris Ensor [ Thu Apr 20, 2017 9:11 am ] |
I'm drooling.... |
Author: | Allen McFarlen [ Thu Apr 20, 2017 3:40 pm ] |
J De Rocher wrote: There are so many details about this instrument to like and they all work together. The oval sound hole really fits the elongated body shape, IMO. Sorry if you have covered this in another thread before, but could you describe how the two-piece pinless bridge works? Is the lighter colored piece behind the main bridge glued to the top? Are the strings threaded through the back end of the light colored piece? The bridge is one piece with a veneer attached to the string platform. I choose a veneer to compliment each instruments timbers. On this one they are string through the sound board with a bead attached to the string and pull up against the bridge patch. Done this way because there is no room for bridge pins on the double courses. On my 4 string instruments I also use a bead and use un-slotted pins as you would with a steel string guitar. Attachment: Bridges.jpg
Author: | J De Rocher [ Thu Apr 20, 2017 8:18 pm ] |
Thanks for the photo and description of your bridges. It's a very cool design and I like how it echoes the headstock shape. |
Author: | Bobc [ Fri Apr 21, 2017 6:29 am ] |
Beautiful uke. Looks like the sapele we had years ago. Never seen anything quite like it again. |
Author: | bcombs510 [ Fri Apr 21, 2017 8:37 am ] |
Allen McFarlen wrote: On this one they are string through the sound board with a bead attached to the string and pull up against the bridge patch. Done this way because there is no room for bridge pins on the double courses. On my 4 string instruments I also use a bead and use un-slotted pins as you would with a steel string guitar. So you put the string in through the top and grab it through the soundhole, then attach the bead? What type of bead? I'm interested because I'm thinking of making a 6 string tenor for my next uke. Also, do you put any CF rods in the neck to account for the extra stress of a 6 string? Thanks! Brad |
Author: | Allen McFarlen [ Fri Apr 21, 2017 3:27 pm ] |
Yes, you push the string through and grab it. Sometimes a bit of bent wire helps to fish it out of the sound hole. I use a 4mm glass or metal bead. If you use a pinned bridge, then they will still fit down the hole as it's around 5mm after the taper. You can get them from the hobby shop for a few bucks for a couple hundred. I don't use CF anymore. I increased the thickness of my fret boards to 5mm with a compound radius on them. I cut stopped fret slots in all of them with my CNC. You'd be surprised at how much stiffer the fret board is when built like that. |
Author: | bcombs510 [ Fri Apr 21, 2017 3:36 pm ] |
I see, so putting a regular bead onto the string and then a knot behind it and pull it up against the bridge plate. Makes sense. I had in my head something that crimps on and I was thinking that would maybe be prone to failure. I have some guitar fretboards from Andy Birko that he calls "faux bound" and they are indeed much more stiff than a typical slotted board. I wonder what the comparison to a bound fretboard would be? In any case, thanks for the info! |
Author: | Allen McFarlen [ Sat Apr 22, 2017 3:17 am ] |
I use a figure 8 knot to tie the bead on. Depending on the brand / type of string you probably need to capture the bead in the knot on the finer strings like the high G and A or you risk pulling the knot right through the bead. A bound fret board is stiffer than an unbound one by a fair bit, but in my experience still not as stiff as the "faux bound" ones. When you add a purfling and glue lines with the bound ones, there does seem to be a bit more "give" to the board. |
